16606 Discussions
VHDL Code and Pin assignments on Terasic TR4
Hello to everyone,
I would like to ask you something about the configuration of pin assignments in VHDL. I would like, before starting to make my question, to say that I am relatively new to VHDL and Quartus II environment, but I have already learned some programming on a DE2 board. I just don´t seem to be able to to the same on the TR4.
I am trying to make an easy blinking LED application, so the first thing I did was to program a VHDL entity called Simple_led, which is taking as input signal an internal 50 Hz oscillator, and it´s letting one of the leds on the board to blink.
Now the code is very easy, I just have somethin like:
entity Simple_led is port(OSC_50_BANK1 : in std_logic; LED : out std_logic_vector(3 downto 0) ); end Simple_led; architecture behavior of Simple_led is signal led_c : std_logic := '0'; begin LED(0) <= led_c; blink : process(OSC_50_BANK1) variable temp : integer := 0; begin if (temp = 50000000) then temp := 0; led_c <= not(led_c); else temp := temp + 1; end if; end process blink; end behavior;
The point is that I have defined the pins correctly following the board manual, and I have even checked that on a demonstration design delivered with the board itself.
Inside the pin assignment the clock signal is exaclty called OSC_50_BANK1, and the leds are LED[0], LED[1], LED[2], LED[3].
When I compile the project I get warnings telling me that:
  • there is one pin which is not driving logic....
  • there is no defined clock inside my design...
This is not clear to me. I have verified my design comparing it with the demonstration project which is written in Verilog, but which basically does the same I am doing in VHDL.
Does anyone have an idea why this is happening? In case I can give you more details.
All the best,
Giovanni.
You should use inside the process a rising_edge(OSC_50_BANK1) to detect the clock rising edge. As I understand you want to increment your variable when you have a clock signal.
So you would have something like this:
entity Simple_led is port(OSC_50_BANK1 : in std_logic; LED : out std_logic_vector(3 downto 0) ); end Simple_led; architecture behavior of Simple_led is signal led_c : std_logic := '0'; begin LED(0) <= led_c; blink : process(OSC_50_BANK1) variable temp : integer := 0; begin if rising_edge(OSC_50_BANK1) then if (temp = 50000000) then temp := 0; led_c <= not(led_c); else temp := temp + 1; end if; end if; end process blink; end behavior;
