17259 Discussions
VHDL: How to initialize RAM from file?
Good timings!
I find in internet-space this vhdl codе:
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; USE IEEE.STD_LOGIC_TEXTIO.ALL; USE STD.TEXTIO.ALL; entity ram_vhdl is Port ( clk : in STD_LOGIC; addr : in STD_LOGIC_VECTOR (9 downto 0); din : in STD_LOGIC_VECTOR (7 downto 0); wen : in STD_LOGIC; dout : out STD_LOGIC_VECTOR (7 downto 0)); end ram_vhdl; architecture Behavioral of ram_vhdl is type TRam is array(0 to 1023) of std_logic_vector(7 downto 0); impure function init_bram (ram_file_name : in string) return TRam is file ramfile : text is in ram_file_name; variable line_read : line; variable ram_to_return : TRam; begin for i in TRam'range loop readline(ramfile, line_read); read(line_read, ram_to_return(i)); end loop; return ram_to_return; end function; signal Ram : TRam := init_bram("bram1.dat"); begin process (clk) begin if clk'event and clk = '1' then if wen = '1' then Ram(conv_integer(addr)) <= din; end if; dout <= Ram(conv_integer(addr)); end if; end process; end Behavioral;
for initialize RAM by data from bram1.dat
But it not work in Quartus... RAM allways filled by zeros...
When i replace lines:
by
ram_to_return(1) := "10000001"; ram_to_return(2) := "10000010"; ram_to_return(3) := "10000011";
Initialization of RAM work properly.
how to initializing ram from external file in vhdl sources?
Sorry for my bad Einglish.
RAM initialization from files through textio library functions is only supported by ModelSim and other simulators, but not by Quartus. For synthesis, you can only use *.hex or *.mif files together with a RAM MegaFunction instance. Verilog readfunctions for binary files are supported by Quartus in constrast.
i use arrays, generics, and packages to initialize RAM
Please raise this issue as a support request with Altera. I have previously requested it, and if others do, then maybe they will finally support it (like Xilinx do!)
