Hello guys ,
I'm implementing a transposed fir filter in vhdl in which only the sum are pipelined. The code I wrote up (using this (http://www.google.it/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0cdaqfjac&url=http%3a%2f%2fwww4.hcmut.edu.vn%2f~hoangtrang%2flecture%2520note%2fdsp%2520on%2520fpga%2fdsp_fpga_ch%252010%2520-%2520fir%2520filter%2520design.pdf&ei=a76eu6uummnp4qt88yggba&usg=afqjcnhr62rzy5-5rvzgccd0nxqz9xaoow&bvm=bv.68911936,d.bge)) until now is the one below:
LIBRARY lpm;
USE lpm.lpm_components.ALL;
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.numeric_std.all;
ENTITY transposed_fir_test IS
GENERIC (W1 : INTEGER := 16; -- Input bit width
W2 : INTEGER := 32; -- Multiplier bit width
W3 : INTEGER := 35; -- Adder width
W4 : INTEGER := 16; -- Output bit width
L : INTEGER := 15; -- Filter length
Mpipe : INTEGER := 0-- Pipeline steps of multiplier
PORT ( clk : IN STD_LOGIC;
Load_x : IN STD_LOGIC;
x_in : IN STD_LOGIC_VECTOR(W1-1 DOWNTO 0);
c_in : IN STD_LOGIC_VECTOR(W1-1 DOWNTO 0);
y_out : OUT STD_LOGIC_VECTOR(W4-1 DOWNTO 0));
END transposed_fir_test;
ARCHITECTURE fpga OF transposed_fir_test IS
SUBTYPE N1BIT IS STD_LOGIC_VECTOR(W1-1 DOWNTO 0);
SUBTYPE N2BIT IS STD_LOGIC_VECTOR(W2-1 DOWNTO 0);
SUBTYPE N3BIT IS STD_LOGIC_VECTOR(W3-1 DOWNTO 0);
TYPE ARRAY_N1BIT IS ARRAY (0 TO L-1) OF N1BIT;
TYPE ARRAY_N2BIT IS ARRAY (0 TO L-1) OF N2BIT;
TYPE ARRAY_N3BIT IS ARRAY (0 TO L-1) OF N3BIT;
SIGNAL x : N1BIT;
SIGNAL y : N3BIT;
SIGNAL c : ARRAY_N1BIT; -- Coefficient array
SIGNAL p : ARRAY_N2BIT; -- Product array
SIGNAL a : ARRAY_N3BIT; -- Adder array
BEGIN
Load: PROCESS ------> Load data or coefficient
BEGIN
WAIT UNTIL clk = '1';
IF (Load_x = '0') THEN
c(L-1) <= c_in; -- Store coefficient in register
FOR I IN L-2 DOWNTO 0 LOOP -- Coefficients shift one
c(I) <= c(I+1);
END LOOP;
ELSE
x <= x_in; -- Get one data sample at a time
END IF;
END PROCESS Load;
SOP: PROCESS (clk) ------> Compute sum-of-products
BEGIN
IF rising_edge(clk) THEN
FOR I IN 0 TO L-2 LOOP -- Compute the transposed
a(I) <= std_logic_vector(signed(p(I)) + signed(a(I+1))); -- filter adds
END LOOP;
a(L-1) <=std_logic_vector(resize(signed(p(L-1)),W3)); -- First TAP has
END IF; -- only a register
y <= a(0);
END PROCESS SOP;
-- Instantiate L pipelined multiplier
MulGen: FOR I IN 0 TO L-1 GENERATE
Muls: lpm_mult -- Multiply p(i) = c(i) * x;
GENERIC MAP ( LPM_WIDTHA => W1, LPM_WIDTHB => W1,
LPM_PIPELINE => Mpipe,
LPM_REPRESENTATION => "SIGNED",
LPM_WIDTHP => W2,
LPM_WIDTHS => W2)
PORT MAP ( dataa => x,
datab => c(I), result => p(I));
END GENERATE;
y_out <=y(W3-1 DOWNTO W3-W4);
END fpga;
By the way using a delta-stimulus of 32767 and this set of coeff: [32437,31463,29888,27779,25230,22351,19269,16118,13036,10157,7608,5500,3924,2950,2621] I get the following output: [X,X,X,X,X,1576,1396,1204,1007,814,634,475,343,245,184,163,0] So it seems I miss the first ouptut samples of the filter and a scaled output.. Any suggestions ?? ty !
to get initial values correctly you need to set accumulators to zero start.
you are scaling by discarding 19 bits. Is that what you wanted?- Mark as New
--- Quote Start --- to get initial values correctly you need to set accumulators to zero start. you are scaling by discarding 19 bits. Is that what you wanted? --- Quote End --- Yep, those X's are related to the initial values of the C matrix. As long as I need only 16 bit I have to take only the MSbs at the output. The magnitude is ok. I was a little confused because the very first values at the output of the filter where not shown due to the lack of initialization of the C matrix. One curiosity, now the filter coefficient are uploaded at the same clock of the input signal. By the way I want to control the coefficient uploading with a different clock (I want to set the coefficient via NIOS PIOs). I've thought to use a first pio to load the coefficient into c_in and a secondo pio to get the c_in loaded (so it acts like the clock of the previus code). I ended up with this code:
-- This is a generic FIR filter generator
-- It uses W1 bit data/coefficients bits
LIBRARY lpm; -- Using predefined packages
LIBRARY ieee;
ENTITY transposed_fir_test IS ------> Interface
W2 : INTEGER := 32; -- Multiplier bit width 2*W1
W3 : INTEGER := 35; -- Adder width = W2+log2(L)-1
rst : IN STD_LOGIC;
wr_clk : IN STD_LOGIC;
SIGNAL x : N1BIT;
SIGNAL y : N3BIT;
BEGIN
x <= x_in;
Load: PROCESS(wr_clk,Load_x) ------> Load data or coefficient
BEGIN
if(rising_edge(wr_clk)) then
c(I) <= c(I+1);
END LOOP;
ELSE
END IF;
end if;
END PROCESS Load;
BEGIN
END LOOP;
y <= a(0);
END PROCESS SOP;
LPM_WIDTHP => W2,
LPM_WIDTHS => W2)
END GENERATE;
END fpga;
Any suggestions ? What can I do if I want to intialize to 0's the C matrix while resetting ? ty !
to initilaise use := (others => (others => '0'));
your dividing by 2^19 may not be right for unity gain. Your output will be scaled somewhere above or below unity- Mark as New
Thank you kaz !
I have never understand if that type initialization is true also during the power up .. could you confirm it ?- Mark as New
--- Quote Start --- Thank you kaz ! I have never understand if that type initialization is true also during the power up .. could you confirm it ? --- Quote End --- yes it is supported as initial values on registers at powerup
