17106 Discussions
VHDL coding issue about AND gate
Hi Dears,
It's very simple to draw single bit AND multi-bit bus in schematic design. i.e: http://www.alteraforum.com/forum/attachment.php?attachmentid=10961&stc=1
However, I have to design analogous fucntion by using an urgly way. i.e:PreMHQ1P <= PosMHQAD and (AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb&AddAndDb);
Is there other simpler way to code above function (such as "PreMHQ1P <= PosMHQAD and AddAndDb;") in VHDL?
PS: AddAndDb is single bit signal, and PreMHQ1P and PosMHQAD are multi-bits bus (the bus width is 21-bit).
(Virus scan in progress ...)
I suggest using if:
if singlebit = '1' then
out <= bus;
else
out < = (others => '0');
end if;
Assuming you are using std_logic and std_logic_vector:
Write a function:
function copyextend( l : std_logic; width : positive) return std_logic_vector is variable r : std_logic_vector( width - 1 downto 0); begin for i in 0 to width-1 loop r(i) := l; end loop; return r; end function ; PreMHQ1P <= PosMHQAD and copyextend( AddAndDb, 21 ) ;
Put the function in a package and you can re-use it everywhere.
--- Quote Start ---
Write a function:
--- Quote End ---
Hi josyb,
Thanks for you reply! The "r(i):=l" should be changed to "r(i):= r(i) and l"?! Am i right?
--- Quote Start ---
I suggest using if:
out <= bus;
else
end if;
--- Quote End ---
Hi kaz,
Yes, it's a simple way than mine. Thanks!
No this function makes a N-wide std_logic_vector filled with copies of the std_logic input argument 'l'.
If you want a function to do the 'and' operation between a std_logic and a std_logic_vector
function "and"( v: std_logic_vector; l : std_logic; width : positive) return std_logic_vector is variable r : std_logic_vector( width - 1 downto 0); begin for i in 0 to width-1 loop r(i) := v(i) and ll; end loop; return r; end function ; PreMHQ1P <= PosMHQAD and AddAndDb ;
This is effectively overloading the and operator. It may seem the nicest solution, but beware: it will be silently applied even if it may not be your intention. So my first solution, copyextend, is clearer as it unequivocally shows the intent of the operation. As a rule: it is not a good idea to overload operators for standard types.
--- Quote Start ---
--- Quote End ---
Hi josyb,
I got it. I'm so sorry that i didn't read your first post carefully. Now, i'm clear. Thank you again for you help.
