17040 Discussions
VHDL design for 8 bit shift register
I need to program an 8 bit shift register, which will be used in a 4-bit multiplier.
Basically, this is what it should do:
1.- Receive inputs x (multiplier), sum (this comes from the adder segment of the multiplier), done, ad, sh, load
2.- WHen it receives the load signal, it must take the input values x
3.- when it gets the done signal, it must stop working
4.- when it gets the ad signal, it must replace the last 4 bits with the sum, also, when it gets sh it must shift
However, I don't seem to get the expected results. This is the code:
LIBRARY IEEE;USE ieee.std_logic_1164.all; Entity registro8 IS PORT (load, sh, ad, Clock, done, z : IN STD_logic; x,sum : IN STD_logic_vector (3 downto 0); m : OUT STD_logic; w : OUT STD_logic_vector(7 downto 0)); END registro8; architecture reg of registro8 IS signal s : std_logic_vector (7 downto 0); begin process (load, x, sum, clock, sh, done, ad) begin if(done = '0') THEN if (load = '1') THEN for i in 4 to 7 loop s(i) <= x(i-4); end loop; for i in 0 to 3 loop s(i) <= '0'; end loop; elsif (clock'event and clock = '1') THEN if (ad = '1') THEN for i in 0 to 3 loop s(i) <= sum(3-i); end loop; elsif (sh = '1') THEN s <= s(6 downto 0) & z; END IF; end if; m <= s(7); w <= s; end if; end process; end reg;
The main problem is that, after loading, the register seems to be deleted. Also, it continues to work, even if the done signal is 1.
Thanks for the help
Read a good book about VHDL, it isn't generic programming language like you are trying to use it.
Your code of the process should look like this:
process (clock, reset)
begin
if(reset = '1') THEN
-- here are the initial conditions
-- here you write what your shift register does
-- if(done = '0') THEN
-- if (load = '1') THEN
-- if (ad = '1') THEN
-- else etc bla bla bla
end if;
end process;
