Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
VHDL "Quantum" bug
Hi all,
I hope nobody has written about this before. I took a look but I found nothing...
I'm a VHDL newbie and I'm facing an issue which is driving me crazy. The thing is that I have designed and implemented a VHDL component, pretty complex if I may say. I coded the RTL model, I refactorized and optimized the code and I checked the RTL netlist to check that it matches with my design. Everything OK. The simulation works as expected too.
The problem comes when I synthetise the design for my DE0 NANO board. I can see that the design works but some parts don't work as expected. There's clearly a bug. After checking all my code, I found nothing so I just added some out ports to the entity to check them with a logic analyser. Those ports add no logic. I just map some internal signals to them to try to monitor what's going on.
However, once I map those signals, everything works as expected. No bugs. Nothing. If I remove the debug ports, the problem appears again.
I don't think this is a speed problem as the maximum frequency I'm using is 1MHz. I also checked all the code and I optimised it for synthesis. I can see using Quartus rtl map viewer that no extra logic is added.
Any clue of what can be hapening? Why there's no bug if I add debuging ports to my entity whilst the design doesn't work well if I remove those ports?
Thanks a lot in advance.
Cheers,
Javier
This sounds like some sort of timing problem - changing the output will change the fit seed and re-route the design, which may now mean that a route that previously failed is a different length that now works.
Do you have timing constraints for the design? How are you using a 1MHz clock? is it logic generated? these are notorious for creating timing problems. Have you synchronised all asynchronous inputs properly?
Hi Tricky,
Sorry for my delayed reply and thank you very much for your reply to my questions.
Actually I considered to add timimg constraints to my design but as the frequency is relatively "low" I thought that it may not be worthy. I certainly was wrong so I will start reading about TimeQuest, timing constraints and SDC in order to learn and apply it to my design.
One more question if I may: Another problem that I had (which clearly seems to be the same) is that some register loopbacks that I had on my design didn't work even when the simulation was perfect. I read, I guess in Quartus Handbook, that register loopbacks should be avoided so I added an extra register on the loopback path and an extra clock cycle and then everything worked out. So I would like to know if this register loopback issue could be fixed with timing constraints as well or if I should keep the registers that I placed on the loopback path.
Sorry for all the questions but I still have a lot to learn here :)
Thanks for your time in advance.
Javier
Not quite sure what you mean by "register loopback"? did you mean logic loops? logic loops are certainly a problem and can only be fixed by removing them.
Yep, That's it.
Javier
