16606 Discussions
VS2010 build opencl host fail problem
I use VS2010 to build opencl host program.
But I can not build it successfully.
Before builing the code, I already run the batch file to st PATH.
But VS2010 still has error message, how to solve it.
The error message as below:
1>InitializeBuildStatus:
1> Touching "x64\Release\matrix_con.unsuccessfulbuild".
1>SetCompileConfig:
1> ERROR: Could not find the 'aocl' command when trying to execute 'aocl compile-config'.
1> Please ensure that '%ALTERAOCLSDKROOT%\bin' is on the path; refer to the Intel(R) FPGA SDK for OpenCL(TM) Getting Started Guide for more information on setting up your environment.
1>
1>Build FAILED.
1>
1>Time Elapsed 00:00:00.02
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
batch file:
set ALTERAOCLSDKROOT=C:\intelFPGA_pro\17.0\hld
set AOCL_BOARD_PACKAGE_ROOT=C:\intelFPGA_pro\17.0\hld\board\a10_ref
set PATH=%ALTERAOCLSDKROOT%\bin;%PATH%;%ALTERAOCLSDKROOT%\host\windows64\bin;%AOCL_BOARD_PACKAGE_ROOT%\windows64\bin;%ALTERAOCLSDKROOT%\windows64\bin
I see multiple spaces in your environmental variables, is this because of bad copy/pasting?
You can open a cmd shell and type "aocl" to see if it works. If it doesn't it means the environmental variables are incorrect.
--- Quote Start ---
--- Quote End ---
Dear HRZ,
multiple spaces is due to copy/past, there is no multiple spaces in my batch file.
I type "aocl compile-config" in cmd shell.
It works, but there is an error message(ERROR: Could not find the 'aocl' command when trying to execute 'aocl compile-config'.) in VS2010.
I still can not build host program in VS2010.
CMD SHELL:
D:\Acer_temp\opencl_altera>aocl compile-config
-IC:/intelFPGA_pro/17.0/hld/host/include
Matt
There must be some problem with the Visual Studio configuration, then. Have you checked your configuration against the steps mentioned in the getting started guide (https://www.altera.com/en_us/pdfs/literature/hb/opencl-sdk/aocl_getting_started.pdf)?
