I use VS2010 to build opencl host program.
But I can not build it successfully. Before builing the code, I already run the batch file to st PATH. But VS2010 still has error message, how to solve it. The error message as below: 1>InitializeBuildStatus: 1> Touching "x64\Release\matrix_con.unsuccessfulbuild". 1>SetCompileConfig: 1> ERROR: Could not find the 'aocl' command when trying to execute 'aocl compile-config'. 1> Please ensure that '%ALTERAOCLSDKROOT%\bin' is on the path; refer to the Intel(R) FPGA SDK for OpenCL(TM) Getting Started Guide for more information on setting up your environment. 1> 1>Build FAILED. 1> 1>Time Elapsed 00:00:00.02 ========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ========== batch file: set ALTERAOCLSDKROOT=C:\intelFPGA_pro\17.0\hld set AOCL_BOARD_PACKAGE_ROOT=C:\intelFPGA_pro\17.0\hld\board\a10_ref set PATH=%ALTERAOCLSDKROOT%\bin;%PATH%;%ALTERAOCLSDKROOT%\host\windows64\bin;%AOCL_BOARD_PACKAGE_ROOT%\windows64\bin;%ALTERAOCLSDKROOT%\windows64\binLink Copied
I see multiple spaces in your environmental variables, is this because of bad copy/pasting?
You can open a cmd shell and type "aocl" to see if it works. If it doesn't it means the environmental variables are incorrect.- Mark as New
--- Quote Start --- I see multiple spaces in your environmental variables, is this because of bad copy/pasting? You can open a cmd shell and type "aocl" to see if it works. If it doesn't it means the environmental variables are incorrect. --- Quote End --- Dear HRZ, multiple spaces is due to copy/past, there is no multiple spaces in my batch file. set PATH=%ALTERAOCLSDKROOT%\bin;%PATH%;%ALTERAOCLSDKROOT%\host\windows64\bin;%AOCL_BOARD_PACKAGE_ROOT%\windows64\bin;%ALTERAOCLSDKROOT%\windows64\bin I type "aocl compile-config" in cmd shell. It works, but there is an error message(ERROR: Could not find the 'aocl' command when trying to execute 'aocl compile-config'.) in VS2010. I still can not build host program in VS2010. CMD SHELL: D:\Acer_temp\opencl_altera>aocl compile-config -IC:/intelFPGA_pro/17.0/hld/host/include D:\Acer_temp\opencl_altera> Thanks, Matt
There must be some problem with the Visual Studio configuration, then. Have you checked your configuration against the steps mentioned in the getting started guide (https://www.altera.com/en_us/pdfs/literature/hb/opencl-sdk/aocl_getting_started.pdf)?
