17255 Discussions
Verilog Code Error: Counter : Read and writer through PIO
SS5
I am trying to read and write 8-bit Counter data Using Quartus and NIOS.
In SOPC : I am assigning PIO : 1-bit input for enable
PIO : 8-bit output for out
module Counter_Top_Level_design ( input clk, rst_n, output wire[7:0] out ); wire enable; always @ (posedge clk or negedge rst_n) begin if (~rst_n) out <= 0; else if (enable == 1'b1) out <= out + 1; end NIOS_SYSTEM niosii_system_inst ( .clk_clk (clk ), // clk.clk .reset_reset_n (rst_n ), // reset.reset_n .output_pio_export ( enable ), // output_pio.export .counter_out_export (out) ); endmodule
I am getting an Error message :
Error (10137): Verilog HDL Procedural Assignment error at Counter_Top_Level_design.v(11): object "out" on left-hand side of assignment must have a variable data type
Error (10137): Verilog HDL Procedural Assignment error at Counter_Top_Level_design.v(13): object "out" on left-hand side of assignment must have a variable data type
Vicky1
output port "out" must have reg data type so replace "output wire[7:0] out" with "output reg[7:0] out"
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Best Regards
Vikas Jathar
(This message was posted on behalf of Intel Corporation)
SS5
module Counter_Top_Level_design ( input clk, output reg[7:0] out ); always @(posedge clk) begin out <= out + 1; end   NIOS_SYSTEM niosii_system_inst ( .clk_clk (clk ), // clk.clk .reset_reset_n (rst_n ), // reset.reset_n .counter_out_export (out) );   endmodule
I have assigned PIO (output):8 bit, its showing error. If i assign PIO (input):8 bit error not coming. But i want to read the counter data.
Vicky1
Have you resolved the issue?
If not, please provide the project file if possible.
Best Regards
Vikas Jathar
SS5
SS5
Sorry, I am not getting the result.
