Verilog Coding
I'm getting the following error when I'm implementing the below Verilog code.
[Synth 8-403] loop limit (65536) exceeded
parameter N=10;
parameter M=8;
parameter depth=(1<<N);
reg [M-1:0]stack_mem[depth-1:0];
always@(posedge clk)
begin
if (rst==1'b1)
begin
next_sp=0;
dataout=0;
for(i=0;i<(depth-1);i=i+1)
begin
stack_mem[i]=0;
end
end
end
Here "For loop" has to increase only up to 1023 but again why I'm getting loop limit exceeded error?
Can anyone help me out?
Thanks in advance.
Where is i declared? Probably should be declared as an integer
Probably like this, with the added text in red:
always@(posedge clk) begin : block_name integer i; if (rst==1'b1) begin next_sp=0; dataout=0; for(i=0;i<(depth-1);i=i+1) begin stack_mem=0; end end end
Note that by requiring that clearing the whole memory in one clock cycle be done, you will be forcing the implementation of stack_mem[] to be done be an array of clearable registers, and not using a block_ram type of memory structure. Hope that is what you intend.
Also clk, rst, next_sp, and dataout need to be declared somewhere (maybe you left out some code ... ?)
Thanks for your response. It's my mistake.i declared "i" as a single bit.
