17255 Discussions
Virtualbox with DE10-Lite USB Scan Problem
GRAVE2
I'm running Ubuntu 18.04 with Virtualbox and extensions running with Centos 6 virtual machine. Quartus Prime 18.1.0 is installed and working, and I have worked through several labs in the "4 Hour FPGA Course".
The lab where the USB Blaster is connected is where I am stuck.
The host machine is Linux Ubuntu 18.04. I had to add group vboxusers. Also configured the Centos machine with USB; Altera USB-Blaster is added.
Within the Centos vm from lsusb:
Bus 002 Device 002: ID 09fb:6001 Altera Blaster
From the host side (Ubuntu) this command:
VBoxManage list usbhost
Altera USB Blaster is "captured".
Using the Tools -> Programmer, I see:
USB Blaster variant [2-1]
So Quartus can see the DE10-Lite board via USB.
Clicking "Auto Detect":
Unable to scan the device chain. Please check the hardware setup.
All looks good to me. Any ideas?
Greg
GRAVE2
Found the USB bus was read only. Changed it:
chmod 666 /dev/bus/usb/002/002
The bus and device numbers in path above found with lsusb inside VM.
GRAVE2
ShafiqY_Intel
Hi Greg, I found almost similar issue on the following forum link. However, this user used usb-blaster II. https://forums.intel.com/s/question/0D50P00003yyT9pSAE/de1soc-dev-kit-trouble-w-usb-blaster-ii-centos7 Since you already found the solution, it’s good for Intel FPGA communities here to know this workaround. Thank you Greg. Regards, Shafiq
