I am getting the warning of Reduced register with stuck data_in port to GND for both "rx_start" and rx_stop" registers. How to work around this. what is the issue ? --------------------------------------------------------------------------- always@ (posedge clk) begin if(~reset ) begin rx_start <= 1'b0; rx_stop <= 1'b0; end else begin rx_start <= (scl_in && pre_scl && ~sda_in && pre_sda); rx_stop <= (scl_in && pre_scl && sda_in && ~pre_sda); end end ----------------------------------------------------------------------Link Copied
