Community
cancel
Showing results for
Search instead for
Did you mean:
SShiv1
Warning(16226): One or more registers failed to be packed into a DSP bank ...
could you please send me the updated template as early as possible.
Nooraini_Y_Intel
Is this thread is the same issue/request as in the following thread link? If this is the not same thread, please of provide details/steps on this issue(error) replication.
https://forums.intel.com/s/question/0D50P0000476TgTSAU/adder-is-not-packed-into-a-dsp-block-in-1st28...
Nooraini
CheePin_C_Intel
​Hi,
I believe this register packing issue is due to the same reason as the forum:
You may refer to the above forum ie to use Native DSP IP or the S10 DSP template to pack the register into DSP bank.
Thank you very much.
Chee Pin
