Hello All, I am curious is there any ways to recrete the current project in another work area while keeping same files, copying all ips? Or is the only way to do this is still copying it manually?
Let's say we have another work area having all the design and tb files ready. Is there any ways to create a project that can import all the design files and constraints while keep the same setting as the old project? The files will be in the same hierarchy in the work area.
You could use the Copy Project command from the Project menu.
Let me know if the suggestion work for you
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
