16592 Discussions
What is Altera equivalent of Xilinx`s IBUF?
Could someone tell if there is similar or equivalent in Altera of Xilinx`s IBUF?
Altera also has IO buffers , these are called ALT_INBUF. Example :
module io_primitives (data_in, data_out); input data_in; wire internal_sig; output data_out; alt_inbuf my_inbuf (.i(data_in), .o(internal_sig)); defparam my_inbuf.io_standard="1.8 V HSTL Class I"; assign data_out = !internal_sig; endmodule
For more information refer https://www.altera.com/en_us/pdfs/literature/ug/ug_low_level.pdf
--- Quote Start ---
--- Quote End ---
How to customize the ALT_INBUF IP core.
For example 4-bit counter
4-bit counter output , how i need to connect to outbuff-diff for 4 bits.
