Hi guys. So I have my Max 10 development kit installed and am checking to be sure I have the drivers installed properly. Quartus Prime 17.1 is running fine. :cool:
But now I have what seems to be a problem. The Intel Max10 Dev board runs the included board software OK, when it comes to using the programmer, I have questions. I have been able to get a simple design to program and run, but only after fiddling with 'auto-detect', and removing a detected hardware called VTAP10. There is no VTAP10 showing up in the tutorial demo I followed, but the tutorial was using 15.0. I could use a little help. What is VTAP10 and how does it fit into the picture? Is the VTAP10 hardware part of the Altera/Intel Development board, or am I looking at a bad USB-blaster driver install or other mess up? What documentation should I reference to understand this part better? Thanks for your help.Link Copied
--- Quote Start --- Is the VTAP10 hardware part of the Altera/Intel Development board, or am I looking at a bad USB-blaster driver install or other mess up? What documentation should I reference to understand this part better? --- Quote End --- Yes, it is virtual JTAG device is provided within the Onboard USB-Blaster II and it provides access to diagnostic hardware and board identification information. Refer MAX 10 FPGA Development Kit User Guide for “VTAP” & bellow thread, https://www.altera.com/en_us/pdfs/literature/ug/ug-max10m50-fpga-dev-kit.pdf http://www.alteraforum.com/forum/showthread.php?t=49595 Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards Vikas Jathar Intel Customer Support – Engineering (Under Contract to Intel)
