16611 Discussions
What's the difference between these two pieces of simple code?
Do you think there is a difference in functionality between these codes?
always @(posedge clk) begin A<=0; if (sel==0) A<=in_u; else A<=in_v; end
always @(posedge clk) begin if (sel==0) A<=in_u; else A<=in_v; end always@(posedgeclk) A<=0;
Yes. The first one will select between in_u and in_v.
In the second one A will be X when the selected input is 1 (and in synthesis, you'll get a multiple driver error)
But how come the first one will not get an error since I am also assigning 0 to A initially. For the second case, I am just doing the same thing, but moving the resetting part to another sequential clock process.
--- Quote Start ---
--- Quote End ---
They are not the same, because the assignment to A in the first always block is always overriden, so A can only be in_u or in_v
In the second one, A is always assigned to 0, but it is also always assigned to in_u or in_v. In this case, if the selected signal is 1, then the 1 drives against 0 to give X
Okay, so that simply means:
1) Assignment in different 'always' blocks --> they are evaluated in parallel, resulting in multiple driver error
2) Assignment in the same 'always' block --> they are evaluated in sequential, where it will reset initially before going into a MUX
--- Quote Start ---
--- Quote End ---
You need to understand the underlying hardware.
1) It generates 2 bits of logic that have both outputs wired together. Each always block creates some logic.
2) Yes - but there is no reset occuring, because the assignment to 0 is overriden and thus ignored.
Ill just clarify:
is identical to this:
always @(posedge clk) begin A<=in_v; if (sel==0) A<=in_u; end
I tried both pieces of code on Vivado. Strange enough, they both passed!
--- Quote Start ---
--- Quote End ---
Not really strange - they are functionally identical.
--- Quote Start ---
--- Quote End ---
I was referring to the code in my initial post. Code# 2 failed in Quartus due to multiple driver error, but passed in Vivado
Was the project set up correctly? Was A removed?
