Could you help check your LM_LICENSE_FILE environment setup. As part of the license setup process, you need to specify the location of the license file using the LM_LICENSE_FILE system variable. You need to set your LM_LICENSE_FILE environment variable to point to the license that Intel provide. c:\intel\license.dat or something similar
You can also to link below for more detailed instructions for Specifying the License File with the LM_LICENSE_FILE or ALTERAD_LICENSE_FILE Environment (page 14)
You can also refer this following youtube for license setup. https://www.youtube.com/watch?v=Ob9ei5lMgGE
Regards, Ray
