17252 Discussions
Why TimeQuest finds no setup paths for input constrained ports???
Hi
I have an RGMII-MAC design, previously described here (http://www.alteraforum.com/forum/showthread.php?t=51437). I also explained my problem in this post (http://www.alteraforum.com/forum/showthread.php?t=51497#post212267), yet no answer!
I hope this forum will help. Any idea is highly appreciated.
Now:
I have constrained my input ports as below:
--- Quote Start ---
# input clock
create_clock -name {phy_rx_clock} -period 8.000 -waveform { 0.000 4.000 } [get_ports {gphy_rxclk}]
#virtual clock for phy
create_clock -name phy_rx_clock_virtual -period 8.000 -waveform { 0.000 4.000 }
#generated clocks
derive_pll_clocks
#clock uncertainty
derive_clock_uncertainty
#input delay
set rgmii_input_delay_min -0.50
set rgmii_input_delay_max 0.50
set rgmii_mac_inputs [get_ports {
gphy_rxctl
gphy_rxd
set_input_delay -clock phy_rx_clock_virtual -min $rgmii_input_delay_min $rgmii_mac_inputs
set_input_delay -clock phy_rx_clock_virtual -max $rgmii_input_delay_max $rgmii_mac_inputs
set_input_delay -clock phy_rx_clock_virtual -clock_fall -min $rgmii_input_delay_min $rgmii_mac_inputs -add_delay
set_input_delay -clock phy_rx_clock_virtual -clock_fall -max $rgmii_input_delay_max $rgmii_mac_inputs -add_delay
#clock groups
set_clock_groups -asynchronous -group {clk_100_mhz} \
-group {u_pll|altpll_component|auto_generated|pll1|clk[0]} \
-group {u_pll|altpll_component|auto_generated|pll1|clk[1]} \
-group {u_pll|altpll_component|auto_generated|pll1|clk[2]} \
-group {u_pll|altpll_component|auto_generated|pll1|clk[3]} \
-group {u_pll_10_to_125|altpll_component|auto_generated|p ll1|clk[0]} \
-group {u_pll_phy_rx_clk|altpll_component|auto_generated|pll1|clk[0]} \
-group {u_s1ll|altpll_component|auto_generated|pll1|clk[0]} \
-group {u_s1pll|altpll_component|auto_generated|pll1|clk[1]}
# false paths
set_false_path -fall_from phy_rx_clock_virtual -fall_to u_pll_phy_rx_clk|altpll_component|auto_generated|p ll1|clk[0] -setup
set_false_path -fall_from phy_rx_clock_virtual -rise_to u_pll_phy_rx_clk|altpll_component|auto_generated|p ll1|clk[0] -setup
set_false_path -rise_from phy_rx_clock_virtual -rise_to u_pll_phy_rx_clk|altpll_component|auto_generated|p ll1|clk[0] -setup
set_false_path -rise_from phy_rx_clock_virtual -fall_to u_pll_phy_rx_clk|altpll_component|auto_generated|p ll1|clk[0] -setup
# multicycles
set_multicycle_path 0 -setup -end -rise_fromphy_rx_clock_virtual -rise_tophy_rx_clock
set_multicycle_path 0 -setup -end -fall_fromphy_rx_clock_virtual -fall_tophy_rx_clock
--- Quote End ---
When I want to see if timing is met using the following commands, the TimeQuest asserts that no setup paths are found! It does report relevant hold paths but not setup ones!
--- Quote Start ---
report_timing -setup -npaths 50 -detail full_path -from_clock {phy_rx_clock_virtual}
report_timing -hold -npaths 50 -detail full_path -from_clock {phy_rx_clock_virtual}
--- Quote End ---
What could be the reason? Why no setup paths are found? How can I ensure that timing is met?
