16808 Discussions
Why does the Quartus fitter fail to pack any ALMs when it does not find a fit?
AGomp
I have a design which is on the limit in terms of FPGA logic utilization. I've noticed that when the fitter fails to find a fit, the "[B] Estimate of ALMs recoverable by dense packing" component of the ALMs needed calculation is 0. When the fitter is able to find a fit, some ALMs are able to be recovered.
+-------------------------------------------------------------------------------------------+ ; Fitter Resource Usage Summary ; +-------------------------------------------------------------+---------------------+-------+ ; Resource ; Usage ; % ; +-------------------------------------------------------------+---------------------+-------+ ; Logic utilization (ALMs needed / total ALMs on device) ; 32,157 / 32,070 ; 100 % ; ; ALMs needed [=A-B+C] ; 32,157 ; ; ; [A] ALMs used in final placement [=a+b+c+d] ; 30,284 / 32,070 ; 94 % ; ; [a] ALMs used for LUT logic and registers ; 13,292 ; ; ; [b] ALMs used for LUT logic ; 11,471 ; ; ; [c] ALMs used for registers ; 5,521 ; ; ; [d] ALMs used for memory (up to half of total ALMs) ; 0 ; ; ; [B] Estimate of ALMs recoverable by dense packing ; 0 / 32,070 ; 0 % ; ; [C] Estimate of ALMs unavailable [=a+b+c+d] ; 1,873 / 32,070 ; 6 % ; ; [a] Due to location constrained logic ; 0 ; ; ; [b] Due to LAB-wide signal conflicts ; 442 ; ; ; [c] Due to LAB input limits ; 1,431 ; ; ; [d] Due to virtual I/Os ; 0 ; ;
From the fitter report snippet above, I would assume that the 5,521 ALMs used only as registers [A.c] would be candidates for packing with the 11,471 ALMs used only as LUT logic [A.b].
Is there a reason that the fitter fails to pack any ALMs in no-fit cases?
Is there a Quartus option that would force the fitter to attempt to pack ALMs?
Kenny_Tan
Try a different seeds, every seeds will have different type of packing and routing, You can refer to https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd05172012_146.html for explanation of packing of AL<
