16608 Discussions
Zero extender and zero checker
1) How can extend an output with zeros in Quartus ii (Schematic / Block)?
2) How can I make a flag named 'zero' to check if an output is zero?
Thank you!
1. Use named association - tie unused bits to ground
2. NOR all of the bits.
--- Quote Start ---
--- Quote End ---
Than you so much but, can you explain more about it? I'm totally a beginner ...
1. Practice using the graphical designer - this is a very basic operation
2. Google it..
I got the second but, the first I did not find it, Can you specify the name and the place where I can find it more? And another Q please, how can I negate a 32-bit input? Thanks again.
