17117 Discussions
altera_pll Fractional-N PLL error using physical output clock parameters
HypeInst
I receive the following error message when attempting to configure the altera_pll MegaCore in Fractional-N mode using physical output clock parameters:
"The specified configuration causes Voltage-Controlled Oscillator (VCO) to go beyond the limit."
My chosen parameters should not be problematic.  Please see the attached screenshot.
Ash_R_Intel
The Fvco achieved by the settings that you had made is beyond the limit specified in the datasheet. For Arria V, Stratix V and Cyclone V device the Fvco min = 600 MHz.
Best way is to first enter the 'Desired Frequency' and let the tool calculate the parameters. You may then adjust the values if more refinement is required.
Please refer, Altera PLL IP Core User Guide, https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/altera_pll.pdf and AN 661, https://www.intel.com/content/www/us/en/programmable/documentation/mcn1424769382940.html for more details.
Regards.
Ash_R_Intel
What is the output frequency that you are trying to achieve?
Regards.
Ash_R_Intel
Regards.
HypeInst
Thank you for your response!  I'm sorry that I previously missed the Fvco limitations.  I see those in the datasheet now and will revise accordingly.  Thanks again!
