amif file format
LarsL1
We are trying to use the following command to update embedded memory blocks in an Arria 10 FPGA:
quartus_cpf --update_emb <input_mif_file> <input_amif_file> <input_sof_file> <output_sof_file>
However, we cannot find information on the input_amif_file format, which should hold address information. How do we specify or generate the amif-file?
ShengN_Intel
I found a similar current post which is on going below.
https://community.intel.com/t5/Intel-Quartus-Prime-Software/Multiple-SRAM-versions-in-a-project/m-p/1358973
Looks like that post is still waiting for a proper solution as well.
Sheng
ShengN_Intel
Based on internal expert feedbacks, this flow seems to be a very internal flow that originally only suit Crypto (Switzerland) use-case. So .amif file is not available for public.
Sheng
ShengN_Intel
Since there are no feedback for this thread, I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, some one will be right with you.
