16018 Discussions
aoc command crashing with -profile switch
Jatin_Kumar
Crash dump:
aoc: Warning: no argument provided for the option -profile, will enable profiling for all kernels by default
aoc: Environment checks completed successfully.
Quartus location: /nfs/site/disks/rtl_ip_simram/tools/intelFPGA_pro/21.1/quartus/bin/quartus_sh
aoc: Cached files in /var/tmp/aocl/ may be used to reduce compilation time
You are now compiling the full flow!!
aoc: Selected target board package /nfs/site/disks/rtl_ip_simram/tools/intelFPGA_pro/21.1/hld/board/s10mx_ref
aoc: Selected target board s10mx_hbm
aoc: Running OpenCL parser....
aoc: OpenCL parser completed
aoc: Linking Object files....
aoc: Optimizing and doing static analysis of code...
aoc: Linking with IP library ...
aocl-llc: /nfs/sc/disks/swip_hld_1/ops/SC/hld/nightly/21.1/173.3/l64/p4/acl/llvm-project/llvm/include/llvm/Support/Casting.h:287: std::enable_if_t<(! llvm::is_simple_type<Y>::value), typename llvm::cast_retty<X, const Y>::ret_type> llvm::cast_or_null(const Y&) [with X = llvm::DILocation; Y = llvm::TypedTrackingMDRef<llvm::MDNode>; std::enable_if_t<(! llvm::is_simple_type<Y>::value), typename llvm::cast_retty<X, const Y>::ret_type> = llvm::DILocation*]: Assertion `isa<X>(Val) && "cast_or_null<Ty>() argument of incompatible type!"' failed.
PLEASE submit a bug report to https://software.intel.com/en-us/support/priority-support and include the crash backtrace.
Stack dump:
0. Program arguments: /nfs/site/disks/rtl_ip_simram/tools/intelFPGA_pro/21.1/hld/llvm/aocl-bin/aocl-llc -march=fpga -board /nfs/site/disks/rtl_ip_simram/tools/intelFPGA_pro/21.1/hld/board/s10mx_ref/hardware/s10mx_hbm/board_spec.xml -profile all -pass-remarks-input=pass-remarks.yaml -dbg-info-enabled --dependendency-list-file=temp_dependencies_list.txt.temp simram.bc -o simram.v
1. Running pass 'Unnamed pass: implement Pass::getPassName()' on module 'simram.bc'.
/nfs/site/disks/rtl_ip_simram/tools/intelFPGA_pro/21.1/hld/llvm/bin/../lib/libLLVM-11git.so(_ZN4llvm3sys15PrintStackTraceERNS_11raw_ostreamE+0x2a)[0x7ffff1f270ba]
/nfs/site/disks/rtl_ip_simram/tools/intelFPGA_pro/21.1/hld/llvm/bin/../lib/libLLVM-11git.so(_ZN4llvm3sys17RunSignalHandlersEv+0x34)[0x7ffff1f24bb4]
/nfs/site/disks/rtl_ip_simram/tools/intelFPGA_pro/21.1/hld/llvm/bin/../lib/libLLVM-11git.so(+0xe7fd03)[0x7ffff1f24d03]
/lib64/noelision/libpthread.so.0(+0x10bd0)[0x7ffff0e98bd0]
/lib64/libc.so.6(gsignal+0x37)[0x7ffff0281f67]
/lib64/libc.so.6(abort+0x13a)[0x7ffff028333a]
/lib64/libc.so.6(+0x2dd66)[0x7ffff027ad66]
/lib64/libc.so.6(+0x2de12)[0x7ffff027ae12]
/nfs/site/disks/rtl_ip_simram/tools/intelFPGA_pro/21.1/hld/llvm/bin/../lib/libLLVM-11git.so(+0xf4f9b5)[0x7ffff1ff49b5]
/nfs/site/disks/rtl_ip_simram/tools/intelFPGA_pro/21.1/hld/llvm/bin/../lib/libLLVM-11git.so(+0x3ec0bca)[0x7ffff4f65bca]
/nfs/site/disks/rtl_ip_simram/tools/intelFPGA_pro/21.1/hld/llvm/bin/../lib/libLLVM-11git.so(+0x3e66fe2)[0x7ffff4f0bfe2]
/nfs/site/disks/rtl_ip_simram/tools/intelFPGA_pro/21.1/hld/llvm/bin/../lib/libLLVM-11git.so(+0x414a547)[0x7ffff51ef547]
/nfs/site/disks/rtl_ip_simram/tools/intelFPGA_pro/21.1/hld/llvm/bin/../lib/libLLVM-11git.so(+0x414a870)[0x7ffff51ef870]
/nfs/site/disks/rtl_ip_simram/tools/intelFPGA_pro/21.1/hld/llvm/bin/../lib/libLLVM-11git.so(+0x414ab7e)[0x7ffff51efb7e]
/nfs/site/disks/rtl_ip_simram/tools/intelFPGA_pro/21.1/hld/llvm/bin/../lib/libLLVM-11git.so(+0x3e6eee0)[0x7ffff4f13ee0]
/nfs/site/disks/rtl_ip_simram/tools/intelFPGA_pro/21.1/hld/llvm/bin/../lib/libLLVM-11git.so(+0x3dcb279)[0x7ffff4e70279]
/nfs/site/disks/rtl_ip_simram/tools/intelFPGA_pro/21.1/hld/llvm/bin/../lib/libLLVM-11git.so(+0x3dcef27)[0x7ffff4e73f27]
/nfs/site/disks/rtl_ip_simram/tools/intelFPGA_pro/21.1/hld/llvm/bin/../lib/libLLVM-11git.so(+0x3dd0282)[0x7ffff4e75282]
/nfs/site/disks/rtl_ip_simram/tools/intelFPGA_pro/21.1/hld/llvm/bin/../lib/libLLVM-11git.so(+0x3dd3fff)[0x7ffff4e78fff]
/nfs/site/disks/rtl_ip_simram/tools/intelFPGA_pro/21.1/hld/llvm/bin/../lib/libLLVM-11git.so(+0x2835671)[0x7ffff38da671]
/nfs/site/disks/rtl_ip_simram/tools/intelFPGA_pro/21.1/hld/llvm/bin/../lib/libLLVM-11git.so(_ZN3acl25GriffinPipelineLegacyPass11runOnModuleERN4llvm6ModuleE+0xef2)[0x7ffff38dd612]
/nfs/site/disks/rtl_ip_simram/tools/intelFPGA_pro/21.1/hld/llvm/bin/../lib/libLLVM-11git.so(_ZN4llvm6legacy15PassManagerImpl3runERNS_6ModuleE+0x412)[0x7ffff2087a42]
/nfs/site/disks/rtl_ip_simram/tools/intelFPGA_pro/21.1/hld/llvm/aocl-bin/aocl-llc(+0x132a8)[0x5555555672a8]
/nfs/site/disks/rtl_ip_simram/tools/intelFPGA_pro/21.1/hld/llvm/aocl-bin/aocl-llc(main+0x351)[0x55555555f211]
/lib64/libc.so.6(__libc_start_main+0xf5)[0x7ffff026d725]
/nfs/site/disks/rtl_ip_simram/tools/intelFPGA_pro/21.1/hld/llvm/aocl-bin/aocl-llc(_start+0x29)[0x55555555f569]
Error: Verilog generator FAILED.
Refer to simram/simram.log for details.
BoonBengT_Intel
Hi @Jatin_Kumar,
Thank you for posting in Intel community forum and hope all is well.
Mind if I ask in which are you facing the following error in DevCloud? If yes can you let is know which node that you are running in?
And which project that are you trying to compile on? Is the simulation a success?
Hope to hear from you soon.
Best Wishes
BB
Jatin_Kumar
Hi BB,
We are not running on DevCloud.
We are trying to develop an IP for which we are using the FPGA for testing purpose. We have not run simulation yet. We have verified the design on emulator, and now trying to implement on FPGA with profiling.
the aoc compiler works perfectly fine without the -profile switch, but when we enable the switch, I keep on getting the above crash dump, even for small design.
Jatin
