asmio_buf.cpp bug
youaltera
Actually, this is more a solution sharing than a question.
So, if during "Assembly" Task you're facing a cpp native code crash on asmio_buf.cpp file while using LVDS SerDes IO core (see picture), the solution is most probably as following:
For Quartus 13 and older:
Assignments -> Settings -> Fitter Settings -> More Settings -> Treat Bidirectional Pin as Output Pin = Off
For newer versions:
Assignments -> Settings -> Compiler Settings -> Advanced Settings (Fitter) -> Treat Bidirectional Pin as Output Pin = Off
But my question is: Is Intel thinking about to fix this bug or they just don't care as many other problems is popping every day since day bought Altera!?
AqidAyman_Intel
Thank you for the sharing. I deeply regret that you are facing this issue.
Can you clarify more on the asmio_buf.cpp file? I will be more than happy to know the background of this issue.
Aqid
AqidAyman_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided, please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
