Hi everyone,
I have a max10 FPGA and I want to assigned a pin to the gnd Because my circuit is like this: output pin(3.3V ) LED power supplied(3.3V) so If I want to light up my LED, I should have an output pin=0V. I've try some VHDL code, it seems it doesn't work library ieee; use ieee.std_logic_1164.all; ENTITY et IS PORT( s : out std_logic ); END et ; ARCHITECTURE data_flow OF et IS BEGIN s<= '0'; END data_flow; I've also tried null instead of 0. But it still doesn't work. is it because I don't have IN std_logic thank you in advanceLink Copied
Did you assign s port to the correct device pin?
thank you for ur replying. Yes I did and i'm sure about that
--- Quote Start --- Because my circuit is like this: output pin(3.3V ) LED power supplied(3.3V) so If I want to light up my LED, I should have an output pin=0V. I've try some VHDL code, it seems it doesn't work --- Quote End --- What is the value of your current limiting resistor? Did you put a scope or a meter to measure the output pin? Kevin Jennings
--- Quote Start --- I've also tried null instead of 0. --- Quote End --- Null would be incorrect, '0' is correct. --- Quote Start --- But it still doesn't work. is it because I don't have IN std_logic --- Quote End --- No Kevin Jennings
The pins can source and drain the required current? I would reccommend using a ground pin. I think there must be a couple of those.
Thank you for your replying,
I couldn't really measure the current, now. Because I work in a starting project. But it was an experimented engineer, who develop that board. So I think he should think about that. I thought it may be have problem of compatibility of USB blaster II, which is not compatible with Altera max10 or the frequency of Jtag, 6MHz instead of 24MHz, but I don't know how to change that frequency- Mark as New
Ok, thank you
--- Quote Start --- What is the value of your current limiting resistor? Did you put a scope or a meter to measure the output pin? Kevin Jennings --- Quote End --- Thank you for your replying, I couldn't really measure the current, now. Because I work in a starting project. But it was an experimented engineer, who develop that board. So I think he should think about that. I thought it may be have problem of compatibility of USB blaster II, which is not compatible with Altera max10 or the frequency of Jtag, 6MHz instead of 24MHz, but I don't know how to change that frequency
--- Quote Start --- The pins can source and drain the required current? I would reccommend using a ground pin. I think there must be a couple of those. --- Quote End --- Thank you for replying, I couldn't use a ground pin. Because I have to manage light up or light down the LED. Could I just connect the ground directly to an output in schematic, does it work?
well, you need to complete the circuit, so it should work, assuming the output can drive enough current.
Topic Options
