--- Quote Start --- how can i write my vhdl code to avoid bounce? --- Quote End --- Draw a flowchart of the basic functionality, and then write a behavioural implementation of that.
Use a counter to generate a suitable interval at which to test the button's input signal. Test it a number of times to see if it persists. Once the signal has passed that test you can declare the button pressed (or released).
I hope that's something you can attempt to code yourself... Cheers, Alex
Topic Options
