17043 Discussions
block diagram - signal ports
i have a big Blockdiagramm in which some signals are crossing very often and cross the whole page. How can i add links to a signal to transfer it from one block to another, or to another block diagram like it is made in pcb-cad-schematics? (like this: http://letsmakerobots.com/files/avr_rescue_shield.png )
You make the same: draw only a branch connected to the block pin and assign it the same name you have on the other branch(es) you want to connect it to.
I never tried with signals on different block files: I don't know if you can do it.
If it's becoming a mess, you may want to investigate HDLs
