17039 Discussions
can <= concatenate into a big message when use it multiple times?
constant preamble : STD_LOGIC_VECTOR (7 DOWNTO 0) := '5555555555555555';
constant dest_mac_addr : STD_LOGIC_VECTOR (5 DOWNTO 0) := '1078D2AD90CB';
constant src_mac_addr : STD_LOGIC_VECTOR (5 DOWNTO 0) := '001234567890';
constant payload : STD_LOGIC_VECTOR (7 DOWNTO 0) := '0001020304050607';
constant wholepacketlength : STD_LOGIC_VECTOR (1 DOWNTO 0) := '22';
variable tx_data : STD_LOGIC_VECTOR(31 DOWNTO 0);
variable CheckSumResult : STD_LOGIC_VECTOR (31 DOWNTO 0);
variable CheckSumValid : STD_LOGIC;
begin
tx_data <= preamble;
tx_data <= dest_mac_addr;
tx_data <= src_mac_addr;
tx_data <= payload;
H2:crcgen port map(
clk => CLOCK_50, --: IN STD_LOGIC;
data => payload, -- : IN STD_LOGIC_VECTOR (7 DOWNTO 0);
datavalid => enableit, --: IN STD_LOGIC;
empty : IN STD_LOGIC_VECTOR (1 DOWNTO 0);
endofpacket : IN STD_LOGIC;
reset_n : IN STD_LOGIC;
checksum => CheckSumResult, --: OUT STD_LOGIC_VECTOR (31 DOWNTO 0);
crcvalid => CheckSumValid --: OUT STD_LOGIC
tx_data <= CheckSumResult;
Did you try to compile it? If this is part of a process it will fail because you can't instantiate a component inside a process. And even if you could, the multiple tx_data <= *** lines would be ignored and only the last one would be synthesized, giving CheckSumResult.
If it is outside a process then the compile will fail because you are trying to assign multiple values to tx_data.
finally i use a & b to concatenate
