the error is that after 59min it goes 60 61 62min....... after 99min, it become 00min 00s00
actually it need to change in hour after 59min i want to show my stopwatch for max 99hr 59min 59s99 this is the stopwatch coding using VHDL library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity stop_watch is Port ( clk : in STD_LOGIC; start : in STD_LOGIC; reset : in STD_LOGIC; hex0 : out STD_LOGIC_VECTOR (3 downto 0); hex1 : out STD_LOGIC_VECTOR (3 downto 0); hex2 : out STD_LOGIC_VECTOR (3 downto 0); hex3 : out STD_LOGIC_VECTOR (3 downto 0); hex4 : out STD_LOGIC_VECTOR (3 downto 0); hex5 : out STD_LOGIC_VECTOR (3 downto 0); hex6 : out STD_LOGIC_VECTOR (3 downto 0); hex7 : out STD_LOGIC_VECTOR (3 downto 0)); end stop_watch; architecture Behavioral of stop_watch is signal count0:std_logic_vector(3 downto 0):=(others=>'0'); signal count1:std_logic_vector(3 downto 0):=(others=>'0'); signal count2:std_logic_vector(3 downto 0):=(others=>'0'); signal count3:std_logic_vector(3 downto 0):=(others=>'0'); signal count4:std_logic_vector(3 downto 0):=(others=>'0'); signal count5:std_logic_vector(3 downto 0):=(others=>'0'); signal count6:std_logic_vector(3 downto 0):=(others=>'0'); signal count7:std_logic_vector(3 downto 0):=(others=>'0'); begin process(clk,reset) begin if reset='1' then count0<=(others=>'0'); count1<=(others=>'0'); count2<=(others=>'0'); count3<=(others=>'0'); count4<=(others=>'0'); count5<=(others=>'0'); count6<=(others=>'0'); count7<=(others=>'0'); elsif rising_edge(clk) then if start='1' then if (count7=x"9" and count6=x"9" and count5=x"5" and count4=x"9" and count3=x"5" and count2=x"9" and count1=x"9" and count0=x"9") then count0<=(others=>'0'); count1<=(others=>'0'); count2<=(others=>'0'); count3<=(others=>'0'); count4<=(others=>'0'); count5<=(others=>'0'); count6<=(others=>'0'); count7<=(others=>'0'); elsif (count6=x"9" and count5=x"5" and count4=x"9" and count3=x"5" and count2=x"9" and count1=x"9" and count0=x"9") then count0<=(others=>'0'); count1<=(others=>'0'); count2<=(others=>'0'); count3<=(others=>'0'); count4<=(others=>'0'); count5<=(others=>'0'); count6<=(others=>'0'); count7<=count7+1; elsif (count5=x"5" and count4=x"9" and count3=x"5" and count2=x"9" and count1=x"9" and count0=x"9") then count0<=(others=>'0'); count1<=(others=>'0'); count2<=(others=>'0'); count3<=(others=>'0'); count4<=(others=>'0'); count5<=(others=>'0'); count6<=count6+1; elsif (count4=x"9" and count3=x"5" and count2=x"9" and count1=x"9" and count0=x"9") then count0<=(others=>'0'); count1<=(others=>'0'); count2<=(others=>'0'); count3<=(others=>'0'); count4<=(others=>'0'); count5<=count5 + 1; elsif (count3=x"5" and count2=x"9" and count1=x"9" and count0=x"9") then count0<=(others=>'0'); count1<=(others=>'0'); count2<=(others=>'0'); count3<=(others=>'0'); count4<=count4 + 1; elsif (count2=x"9" and count1=x"9" and count0=x"9") then count0<=(others=>'0'); count1<=(others=>'0'); count2<=(others=>'0'); count3<=count3 + 1; elsif (count1=x"9" and count0=x"9") then count0<=(others=>'0'); count1<=(others=>'0'); count2<=count2 + 1; elsif (count0=x"9") then count0<=(others=>'0'); count1<=count1 + 1; else count0<=count0 + 1; end if; end if; end if; end process; hex0<=count0; hex1<=count1; hex2<=count2; hex3<=count3; hex4<=count4; hex5<=count5; hex6<=count6; hex7<=count7; end Behavioral;Link Copied
you haven't constrained your counters.
I will do it as nested ifs starting from count0 towards count7:
library IEEE;
Port (
clk : in STD_LOGIC;
end stop_watch;
begin
process(clk,reset)
begin
if reset = '1' then
count0 <= (others=>'0');
count1 <= (others=>'0');
count2 <= (others=>'0');
count3 <= (others=>'0');
count4 <= (others=>'0');
count5 <= (others=>'0');
count6 <= (others=>'0');
count7 <= (others=>'0');
if start='1' then
if count0 /= x"9" then
count0 <= count0 + 1;
else
count0 <= x"0";
if count1 /= x"9" then
count1 <= count1 + 1;
else
count1 <= x"0";
if count2 /= x"9" then
count2 <= count2 + 1;
else
count2 <= x"0";
if count3 /= x"5" then
count3 <= count3 + 1;
else
count3 <= x"0";
if count4 /= x"9" then
count4 <= count4 + 1;
else
count4 <= x"0";
if count5 /= x"5" then
count5 <= count5 + 1;
else
count5 <= x"0";
if count6 /= x"9" then
count6 <= count6 + 1;
else
count6 <= x"0";
if count7 /= x"9" then
count7 <= count7 + 1;
else
count7 <= x"0";
end if;
end if;
end if;
end if;
end if;
end if;
end if;
end if;
end if;
end if;
end process;
hex0 <= count0;
hex1 <= count1;
hex2 <= count2;
hex3 <= count3;
hex4 <= count4;
hex5 <= count5;
hex6 <= count6;
hex7 <= count7;
end Behavioral;
Thank sir
I will test it after I cameback from sch- Mark as New
hello sir
for the time set, i need to do with keypad or keyboard. i don't know how to write for this code.- Mark as New
this is the time to show in LCD. i cannot find the problem. i want to show hour for 01-12. but its also include 00. so after 12hr it become 00hr and then 01 hr. that is the wrong. can u find the error, sir. plz help me. that is very important for me ................. thank sir
------------------------------------------------------------------------------------------------------------------------ library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity counter_up is Port ( clk : in STD_LOGIC; SET : in STD_LOGIC; BTN0 : in STD_LOGIC; BTN1 : in STD_LOGIC; BTN2 : in STD_LOGIC; BTN3 : in STD_LOGIC; BTN4 : in STD_LOGIC; BTN5 : in STD_LOGIC; reset : in STD_LOGIC; AM : out STD_LOGIC; hex0 : out STD_LOGIC_VECTOR (3 downto 0); hex1 : out STD_LOGIC_VECTOR (3 downto 0); hex2 : out STD_LOGIC_VECTOR (3 downto 0); hex3 : out STD_LOGIC_VECTOR (3 downto 0); hex4 : out STD_LOGIC_VECTOR (3 downto 0); hex5 : out STD_LOGIC_VECTOR (3 downto 0)); end counter_up; architecture Behavioral of counter_up is signal count0:std_logic_vector(3 downto 0):=(others=>'0'); signal count1:std_logic_vector(3 downto 0):=(others=>'0'); signal count2:std_logic_vector(3 downto 0):=(others=>'0'); signal count3:std_logic_vector(3 downto 0):=(others=>'0'); signal count4:std_logic_vector(3 downto 0):=x"1"; signal reg:std_logic:='0'; begin process(clk,reset) begin if reset='1' then count0<=(others=>'0'); count1<=(others=>'0'); count2<=(others=>'0'); count3<=(others=>'0'); count4<=x"1"; elsif rising_edge(clk) then if SET='1' then if (count0=x"9" and BTN0='1') then count0<=x"0"; elsif (BTN0='1') then count0<=count0+1; elsif (count1=x"5" and BTN1='1') then count1<=x"0"; elsif (BTN1='1') then count1<=count1+1; elsif (count2=x"9" and BTN2='1') then count2<=x"0"; elsif (BTN2='1') then count2<=count2+1; elsif (count3=x"5" and BTN3='1') then count3<=x"0"; elsif (BTN3='1') then count3<=count3+1; elsif (count4=x"C" and BTN4='1') then count4<=x"1"; elsif (BTN4='1') then count4<=count4+1; elsif(BTN5='1') then reg<=not(reg); end if; else if (count4=x"C" and count3=x"5" and count2=x"9" and count1=x"5" and count0=x"9") then reg<=not(reg); count0<=(others=>'0'); count1<=(others=>'0'); count2<=(others=>'0'); count3<=(others=>'0'); count4<= x"1"; elsif (count3=x"5" and count2=x"9" and count1=x"5" and count0=x"9") then count0<=(others=>'0'); count1<=(others=>'0'); count2<=(others=>'0'); count3<=(others=>'0'); count4<=count4 + 1; elsif (count2=x"9" and count1=x"5" and count0=x"9") then count0<=(others=>'0'); count1<=(others=>'0'); count2<=(others=>'0'); count3<=count3 + 1; elsif (count1=x"5" and count0=x"9") then count0<=(others=>'0'); count1<=(others=>'0'); count2<=count2 + 1; elsif (count0=x"9") then count0<=(others=>'0'); count1<=count1 + 1; else count0<=count0 + 1; end if; end if; end if; end process; AM <= reg; hex0<=count0; hex1<=count1; hex2<=count2; hex3<=count3; hex4<= count4 when (count4<x"A") else "00"&count4(2 downto 1) when count4=x"C" else "00"&count4(0); hex5<= "0001" when (count4=x"A" or count4=x"B" or count4=x"C") else "0000"; end Behavioral;
