Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
clock division
Greetings everyone, I'm trying to divide the clock frequency by 2, 4, 8 for a (4x1 Multiplexer) in which the first input is the clock but the other three are the clock divided by the above numbers. Could anybody show me how to do it? I would be very grateful
Your code currently does nothing for several reasons:
1. You are only trying to initialise the variables - they are not changing dynamically
2. You cannot divide a single bit by anything.
I suggest using a counter somewhere.
I also suggest you do not use the clock any any logic equation, or generate a clock from logic. Doing this is very bad practice - you need to generate clock enables instead.
Highlighted
Thank you for your advice. I will consider it thoroughly.
