Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
clock problem
greetings
hi guys
am having an assignment which it basically a car park machine
it has 4 inputs
which is fifty , twenty, ten, ticket
and i need to detect the input and deduct it from an amount of 1.50
so basically i made the design for the stages
and the decoder to view it in four 7-seg bcd
which starts with
insert ticket
then remove ticket
then the 1.50 to check the input of the user
and heres my problem comes
when i apply the code in de1 altera board
the 7-seg doesn't show the first two stages it goes straight away to the 1.50 stage , that happens due to the clock is so fast
even the inputs, lets say i pressed the input 50 the whole process can be done with single press
and am using 50MHZ clock
so i tried to use a clock divider code to reduce it to 1HZ
but it seems that the problem is still there
so is there any way that i can slow the clock so the first two stages can be shown to the user
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity clk200 is
Port (
clk_in : in STD_LOGIC;
rst1 : in STD_LOGIC;
clk_out: out STD_LOGIC
end clk200;
architecture Behavioral of clk200 is
signal temporal: STD_LOGIC;
signal counter : integer range 0 to 49999999 := 0;
begin
frequency_divider: process (rst1, clk_in) begin
if (rst1 = '1') then
temporal <= '0';
counter <= 0;
elsif rising_edge(clk_in) then
if (counter = 49999999) then
temporal <= NOT(temporal);
counter <= 0;
else
counter <= counter + 1;
end if;
end if;
end process;
clk_out <= temporal;
end Behavioral;
what i need is method that slow down the clock to the lowest
thank
Highlighted
