17255 Discussions
clock type mismatch in incremental compiles
I have a design that is partitioned, logic-logic locked and subsequently placed and routed successfully. But later when I recompile the design with some changes in a different area of the design, I get clock type mismatch errors such as -
Error (176363): Can't use clock type Regional Clock at location CLKCTRL_R32 for clock control block or source node control_link:pf_link|control_link_slite2_top:control_link_slite2_top_inst|control_link_slite2_xcvr:xcvr_inst|alt4gxb:alt4gxb_component|alt4gxb_03t9:auto_generated|tx_clkout[0] with clock type Periphery Clock -- clock types do not match
The design partition properties are set to use post-fit netlist including routing information. The logic-lock properties are set to fixed. Making the region reserved in logic-lock properties doesn't help.
Any ideas? I cannot figure out what is causing Quartus (11.1 sp2) to loose the routing information.
TIA
Sanjay
If I were to take a guess, it is locked to CLKCTRL_R32 but the internal promotion is making it a periphery clock. I don't believe assigning a clock to a specific location such as CLKCTRL_R32 guarantess it will be promoted to a regional. (It seems silly, but very seldom do users lock down to specific Regional locaitions). Now, when I've used partitions set to post-fit, this has always been resolved for me through the partition, so not sure why it wouldn't occur here, unless perhaps the source transceiver is outside of the partition? Just a guess. Maybe take that name into the Assignment Editor and make a Global assignment of type Regional. Just a guess though.
These didn't help.
But I am puzzled as to why none of the clocking and calibration features such as PLLs, DLLs, calibration blocks, etc. are not included in the design partition statistics.
Altera support asked me to add this to quartus.ini - fsac_clock_manager_merge_all_hssi_tx_pcs_in_same_quad=off
Not sure what it does but I have since then started getting internal error when I recompile with an existing database.
----------error msg begin ----------
Internal Error: Sub-system: CDB_ATOM, File: /quartus/db/cdb_atom/cdb_atom_tgx_lcell.cpp, Line: 854
Atom# 406195 - get_lutmask() called for non-consistent arithmetic lcell comb
Stack Trace:
0x13d66d: CDB_ATOM_TGX_LCELL_COMB::get_transformed_lutmask + 0x57d (db_cdb_atom)
0x13dd60: CDB_ATOM_TGX_LCELL_COMB::get_lutmask + 0x160 (db_cdb_atom)
0x18744e: CDB_ATOM_LUTMASK_CACHE::visit_atom_tgx_lcell_comb + 0xae (db_cdb_atom)
0x186aff: CDB_ATOM_LUTMASK_CACHE::init_data + 0x7f (db_cdb_atom)
0x186dd2: CDB_ATOM_LUTMASK_CACHE::CDB_ATOM_LUTMASK_CACHE + 0x92 (db_cdb_atom)
0x188967: CDB_ATOM_LUTMASK_CACHE::init_lutmask_cache + 0xe7 (db_cdb_atom)
0xb62a: a2t_call_update_tdb_netlist_for_atoms + 0x9f7a (tsm_a2t)
0xbf74: a2t_call_update_tdb_netlist_for_atoms + 0xa8c4 (tsm_a2t)
0xd54a: a2t_call_recursive_visitor + 0xa (tsm_a2t)
0x3fa7: sta_update_tdb_netlist_for_atoms + 0xe67 (TSM_STA)
0xb98b: sta_build_and_preprocess_tdb + 0x15b (TSM_STA)
0x164a4: tdc_get_accessories + 0x53c4 (TSM_TDC)
0xef93a: FITCC_TDC_UTILITY::setup_tdc_utility + 0x4ba (FITTER_FITCC)
0xf1fa9: FITCC_TDC_UTILITY::FITCC_TDC_UTILITY + 0x1e9 (FITTER_FITCC)
0x3a42b: FITCC_ENV::get_tdc_utility_or_create_if_necessary + 0x35b (FITTER_FITCC)
0x217e3e: FSAC_AUTO_DELAY_CHAIN_OP::work_new + 0x1be (FITTER_FSAC)
0x1fda49: FSAC_DELAY_CHAIN_OP::work + 0x1d9 (FITTER_FSAC)
0x84ce: FTITAN_LUT_RAM_CONVERSION_UTIL::lutram_iterm_port_is_internal_registered + 0x4c1e (fitter_ftitan)
0x462f7: FITCC_EXPERT::fitter_post_operations + 0x1a7 (FITTER_FITCC)
0x475c5: FITCC_EXPERT::invoke_fitter + 0xa55 (FITTER_FITCC)
0x29c5: ftitan_execute + 0x265 (fitter_ftitan)
0xb55d: fmain_start + 0x7cd (FITTER_FMAIN)
0x1264b: qexe_get_command_line + 0x1c5b (comp_qexe)
0x1588d: qexe_process_cmdline_arguments + 0x5ad (comp_qexe)
0x159a1: qexe_standard_main + 0xa1 (comp_qexe)
0x1a48: MSG_INITIALIZER::~MSG_INITIALIZER + 0x118 (CCL_MSG)
0x19ec: MSG_INITIALIZER::~MSG_INITIALIZER + 0xbc (CCL_MSG)
0x53d4: MEM_INITIALIZER::~MEM_INITIALIZER + 0x244 (ccl_mem)
0x3379f: msg_exe_main + 0x8f (CCL_MSG)
0x1652c: BaseThreadInitThunk + 0xc (kernel32)
0x2c520: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Quartus II 64-Bit Version 11.1 Build 259 01/25/2012 SJ Full Version
Service Pack Installed: 2
----------- error msg end -------------
