Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
combinational loops as latches produced while using generate & for
PLease see the attached files.
I am trying to get some feelings on warnings for combinational loops as latches. The first attached file generates many inferred latches. By adding a clocks, the second attachment generates 512 combinational loops as latches.
Any analysis on the situation? And any advice on how to fix the warning while keeping the original functionality?
It's completely unclear what you are trying to achieve. You are describing asynchronous "memory" by writing data under always @(*). It can be only synthesized as combinational loop with recent Altera FPGA.
There's no significant difference between both examples regarding latch inference.
