Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
compatible parameter origins and overriding
After Qsys system generation:
- What are the origins of "compatible" parameter (later used in Device Tree Blob) in generated .sopcifo/.xml files?
- And is it possible to override this parameter using Quartus tools?
Device Tree related information in .sopcinfo file is set during qsys - generate process. qsys searches ip core's directory for *_hw.tcl script, where device tree related commands may reside.
for example
set_module_assignment embeddedsw.dts.vendor "ALTR"
set_module_assignment embeddedsw.dts.group "msgdma"
set_module_assignment embeddedsw.dts.name "msgdma-dispatcher"
set_module_assignment embeddedsw.dts.compatible "ALTR,msgdma-dispatcher-1.0"
overriding can be achieved with editing these scripts
