17252 Discussions
control stepper using de0 nano
hii....
how to control a stepper motor that can move 50 degrees?
I guess you need to calculate, how many pulses you need to send to your motor to move these 50 degree and send them with suitable (low enough) frequency.
1.8 degrees in one step<><>
this my program.,. but still looping. how to stop it in order to move 30 degrees only
library IEEE;
use ieee.std_logic_1164.all;
entity stepper is
port ( CLK : in std_logic;
tombol_arah : in std_logic;
STEP_D : out std_logic_vector (3 downto 0)
end stepper;
Architecture behavioral of stepper is
signal cnt : integer range 0 to 3;
signal cnt_1 : integer range 0 to 3;
begin
process (CLK) is
begin
if (CLK'event and CLK = '1') then
case cnt is
when 0=>
STEP_D <= "1001";
when 1=>
STEP_D <= "0001";
when 2=>
STEP_D <= "0011";
when 3=>
STEP_D <= "0010";
end case;
end if;
end process;
process (CLK)
begin
if(CLK' event and CLK = '1') then
if cnt = 3 then
cnt <= 0;
else
cnt <= cnt+1;
end if;
end if;
end process;
end behavioral;
library IEEE;
entity steper is
end steper;
Architecture behavioral of steper is
begin
process (CLK) is
begin
case cnt is
when 0=>
STEP_D <= "1001";
when 1=>
STEP_D <= "0001";
when 2=>
STEP_D <= "0011";
when 3=>
STEP_D <= "0010";
end case;
end if;
end process;
process (CLK)
begin
if cnt = 3 then
cnt <= 0;
else
cnt <= cnt+1;
end if;
end if;
end process;
end behavioral;
Add another counter, that counts 30 or 50 degrees and when it reaches the certain value it stops rotation. Use enable signal in first process and add a wider counter to the second process.
