17255 Discussions
couldn't run EDA simulation library compiler
dsun01
New Contributor III
Dear Support,
I am learning how to use Quartus Pro, under tools-> launch simulation library compiler, I filled the executable location correctly.  I confirmed that the vsim.exe is there. but the tools keep asking me to "specify the simulation tools executable location".  this really confuse me.
please give instruction/hint how to set up the location correctly. the Quartus is 21.3.
the Questa is 2021.04.
I posted this question before, but accidently put a wrong solution and accepted, but actuarily I still couldn't make this work.
thank you
IntelSupport
Community Manager
Hi David,
Please allow me some time to reproduce the error
and will be back with updates. Thanks
Pavee
IntelSupport
Community Manager
Hi David,
Just to check with you, have you add /vsim.exe in "Executable Location"?
If no, kindly try to add /vsim.exe. If the issue still persist, kindly do let me know.
Pavee
dsun01
New Contributor III
Hi Pavee,
That was my initial post asking for,  when I put in the path of "Executable Location", the Quartus would not accept. I installed Questa, I can execute it with no problem.  QuestaSim is the only option for Quaruts Pro. and the path is correct. but I don't understand why Quartus keep asking me to specify the simulation tool executable location. I guess I misunderstand some terminology.  I hope I can get help in this forum.
Thank you for your reply, hope you can give me some suggestion to make this work.
David
