Hi..I want to make counter for 4096 quadrature ticks / revolution.that means it will count 4096 ticks for one rotation of my Encoder shaft.
I dont know why my code is not working..Please look it n give me correction.. Code is library IEEE; use IEEE.std_logic_1164.all; use IEEE.std_logic_arith.all; use IEEE.std_logic_unsigned.all; use work.mem.all; Entity single is port(clk:in bit; msbinv:in std_logic; DOUT:in std_logic; OUT_PUT1:out std_logic_vector(12 downto 1); SCL:inout std_logic; NSL :inout std_logic); End Entity single; Architecture single_calc of single is signal counter : std_logic_vector(12 downto 1); begin trans:process(clk) variable cnt : integer range 0 to 160; begin // code for 24 mhz to 4 mhz clock divider if(clk'event and clk='1') then cnt:=cnt +1; if (cnt>=0 and cnt<3) then NSL <= '1'; --cnt:= cnt+1; elsif (cnt>=3 and cnt<6) then NSL <='0'; SCL <= '0'; -- cnt := cnt + 1; elsif (cnt>=6 and cnt<9) then SCL <='1'; -- cnt := cnt + 1; elsif (cnt>=9 and cnt<12) then SCL <= '0'; --cnt := cnt + 1; elsif (cnt>=12 and cnt<15) then SCL <='1'; -- cnt := cnt + 1; elsif (cnt>=15 and cnt<18) then SCL <='0'; -- cnt := cnt + 1; elsif (cnt>=18 and cnt<21) then SCL <='1'; -- cnt := cnt + 1; elsif (cnt>=21 and cnt<24) then SCL <='0'; -- cnt := cnt + 1; elsif (cnt>=24 and cnt<27) then SCL <='1'; -- cnt := cnt + 1; elsif (cnt>=27 and cnt<30) then SCL <='0'; --cnt := cnt + 1; elsif (cnt>=30 and cnt<33) then SCL <='1'; -- cnt := cnt + 1; elsif (cnt>=33 and cnt<36) then SCL <='0'; elsif (cnt>=36 and cnt<39) then SCL <='1'; elsif (cnt>=39 and cnt<42) then SCL <='0'; elsif (cnt>=42 and cnt<45) then SCL <='1'; elsif (cnt>=45 and cnt<48) then SCL <='0'; elsif (cnt>=48 and cnt<51) then SCL <='1'; elsif (cnt>=51 and cnt<54) then SCL <='0'; elsif(cnt>=54 and cnt<57) then SCL <='1'; elsif (cnt>=57 and cnt<60) then SCL <='0'; elsif (cnt>=60 and cnt<63) then SCL <='1'; elsif (cnt>=63 and cnt<66) then SCL <='0'; elsif (cnt>=66 and cnt<69) then SCL <='1'; elsif (cnt>=69 and cnt<72) then SCL <='0'; elsif (cnt>=72 and cnt<75) then SCL <='1'; elsif (cnt>=75 and cnt<78) then SCL <='0'; elsif (cnt>=78 and cnt<81) then SCL <='1'; elsif (cnt>=81 and cnt<84) then SCL <='0'; elsif (cnt>=84 and cnt<87) then SCL <='1'; elsif (cnt>=87 and cnt<90) then SCL <='0'; NSL <= '1'; cnt:= 0; end if; end if; end process trans; // SCL toggle 13 times and at that time NSL is '0' ; pros1:process(SCL,NSL) begin if(SCL'event and SCL='1') then if NSL = '0' then if(msbinv = '1') then counter <= counter + "000000000001"; end if; if (msbinv = '0') then counter <= counter - "000000000001"; end if; end if; end if; out_put1 <= counter ; end process pros1; End Architecture single_calc; I would be thankful to you.. Thank you.Link Copied
