I want to use synopsys VCS to run post-synthesis simulation.
In quartus_install_dir/eda/sim_lib/aldec & memtor can find cyclonev_atom_ncrypt.v, but VCS can't use it.
How can I get the cyclonev_atom_ncrypt.v for VCS?
You can just go to quartus -> tools -> launch simulation compiler to generate the library for your VCS.
Thanks for your response.
In quartus -> tools -> launch simulation compiler can't find VCS.
Are you using windows? Vcs only support in Linux. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-tp-simulation.pdf
So I need to install quartus linux version then launch simulation compiler to generate the library for your VCS,right?
If you were using windows, you will need to switch to Linux version and install the quartus Linux version. Quartus Linux version would not be supported in windows platform. Thanks
