Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
delay a signal by several clk cycles in verilog
Is there anyone knows an easier way to delay a signal by several clk cycles in verilog
I was trying to use repeat as below, however, it only works when I run RTL simulation, it will not work when I run gate level simulation.
data_out <= repeat (15) @(posedge clk ) data;
Thanks!!
--- Quote Start ---
Thanks!!
--- Quote End ---
It's called a SHIFT REGISTER. Google: shift register verilog code
