eCPRI IP compile issue
Anantharaj
I have generated the eCPRI IP. When i try to compile the IP in the Intel Quartus v21.4 software, the compilation is not happening.
After couple of hrs,
It reports "Verilog or VHDL error" : cannot open verilog file 'ipcore/ip_ecpri/ecpri_141/synth/*.sv'.
At the same time, the Compile process status is still 0%.
Please provide your support to understand this.
Note: I have attached the screen shot.
Thank you,
Ananth
Kshitij_Intel
Hi Ananthraj,
Can you please share your project to replicate the issue.
Have you connected the ports?
Thank you
Kshitij Goel
Kshitij_Intel
Also, please try with eCPRI example design https://www.intel.com/content/www/us/en/docs/programmable/683837/21-2-1-3-1/quick-start-guide.html
Thank you
Kshitij Goel
Kshitij_Intel
Also, It seems to be path issue. Please check your path.
Thank you
Kshitij Goel
Kshitij_Intel
As We do not receive any response from you to the previous reply that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
Thank you.
