16596 Discussions
eda sim_lib vlog compile error...missing tennm_atoms_ncrypt.sv
Patriet
Trying to conpile eda sim_libs for Mentor and getting an error about missing .sv file.  Error is below.
Error: # ** Error: (vlog-7) Failed to open design unit file "/apps/quartus_prime/19.2.0/install/quartus/eda/sim_lib/mentor/tennm_atoms_ncrypt.sv" in read mode
This file seems to exist in some versions of Quartus (found it in 19.4) but not in others.  Where do these files come from?  Why are they differnet from version to version?  Should I have tennm_atoms_ncrypt.sv in 19.2 or 19.3 sim_libs?
Thanks for any replies!
RichardTanSY_Intel
Yes, once you installed the Agilex device, the .sv file will be shown.
RichardTanSY_Intel
I believe the files is used for Agilex devices. I checked,  starting from Quartus Pro version 19.1 and onwards you should be able to see the tennm_atoms_ncrypt.sv files located in the <installation directory>/quartus/eda/sim_lib/mentor/
Patriet
Thanks for the reply.  Does that mean those .sv files will not show up unless I install the agilex device family maybe??
RichardTanSY_Intel
Patriet
Thank you, that worked.  I installed the Agilex device family and the missing files appeared.  Please note that Agilex devices are not supported until 19.3.
