hi my friends,
this is my code: i want to change the value of "loop_ends" at the end of loopS.but at the end, it never becomes '1' . what should i do ? L1:for s in 0 to NSTAGES-1 generate
L2:for t in 0 to 2**s-1 generate
begin
DUT: entity work.mux
port map (
clk => clk,
data => n(input_index_end downto input_index_start),
input => n(output_index),
output => m(output_index)
end generate;
loop_ends<='1' when s=NSTAGES-1 else '0';
end generate;
Why would you want this?
A for-generate expands in place (instantiates a series of components) not in time.- Mark as New
--- Quote Start --- Why would you want this? A for-generate expands in place (instantiates a series of components) not in time. --- Quote End --- i wanna found when output of loops is prepare, when "loop_end" become '1' i found i can use the output!
josyb already anwered you.
VHDL generate loops are NOT sequential instruction loops in the sense of a common software programming language. Loops simply instantiate the array of components you specified; this way you don't need to write manually the single stages. So the output is immediately ready, apart any delay caused by the actual logic function you implemented.- Mark as New
thanks my friends,u r right
