17254 Discussions
error while simulating a design which is using mega fuction core.
I have generated lpm_counter mega function IP using Mega wizard pluggin manager wheich i have used it in my verilog design. I am using modelsim 10.0c altera SE. I am invoking this using quartus 11.1. I am getting an error while simulating which is "Error:(vsim-3033)". Should i need to add any libraries or is there any other wayn to successfully simulate the design.
Thank you.
the EDA tab of the LPM_COUNTER tells you what libraries you'll need, which in this case is the LPM/220model
however, those libraries should be setup with ModelSim-A(S)E. can you paste the whole log?
