hi there,
i'm new in fpga world and i just started playing with megafunctions, and already encountered problems. i'm trying to adapt a working structure on xilinx to altera(the project isn't mine, i just have to adapt it to altera, so i can learn more about this job). i'm using a module with different clocks for read and write, asynchronous reset, and only the rdempty signal. when i simulate the entire module, after inserting some data's, i try to read them, but the "q" signal is zzzzz :( i also noticed that the rdempty signal is in a hi-z state. i replaced the megafunction fifo with a manual made module, having the same properties(different clocks, rdempty signal) and it works properly. Any ideas? pleaseLink Copied
--- Quote Start --- hi there, i'm new in fpga world and i just started playing with megafunctions, and already encountered problems. i'm trying to adapt a working structure on xilinx to altera(the project isn't mine, i just have to adapt it to altera, so i can learn more about this job). i'm using a module with different clocks for read and write, asynchronous reset, and only the rdempty signal. when i simulate the entire module, after inserting some data's, i try to read them, but the "q" signal is zzzzz :( i also noticed that the rdempty signal is in a hi-z state. i replaced the megafunction fifo with a manual made module, having the same properties(different clocks, rdempty signal) and it works properly. Any ideas? please --- Quote End --- Did you fix your problem? I have similar problems since my q is also Z. Just to note, Altera-ModelSim only supports Altera's Megafuctions, if you are using any Xilinx IP on it, it will fail.
I'm using a .tcl file for simulating. To work, you'll have to add the altera_mf library to the simulation. I've used the following code line:vsim -L altera_mf -t ns work.test_fifo
--- Quote Start --- Hi, I'm using a .tcl file for simulating. To work, you'll have to add the altera_mf library to the simulation. I've used the following code line:
--- Quote End --- I think I do add the altera_mf library.
