for loop in sdc file
is it possible to use for loops in the sdc file to help add constraints for multiple interfaces of the same type.
For example, I have 4 ata intefaces and so it would be easier if I could have a for loop setting the contraints the same for each.
I have tried the code below which doesn't work, I get the error
"Warning: Ignored filter at squid.sdc(115): ATA$x_DD
[*] could not be matched with a port" and "Warning: Ignored filter at squid.sdc(115): ATA$x_IORDY could not be matched with a clock".
for {set x 0} {$x<4} {incr x} { set_input_delay -max 2.3 }] -clock }Thanks in advance,
Richard
SDC is just tcl with a different extension so yes, you can use loops. But they need to be correct tcl syntax.
In your code, tcl has no way to tell that you want to replace $x instead of $x_DD. I don't have access to Quartus to try but I believe you need to use ${x}_DD. If that does not work, simply use string manipulation to build the signal name before using it:
Set signal "ATA"
String append $signal $x
String append "_DD"
Or something like that.
Hope this helps
DK
Thanks for the help, I couldn't get the first method to work but the second one does with some slight changes. I ended up with
set data_in "ATA" append data_in $x append data_in "_DD"Thanks again,
Richard
BKevi
I think you can put all varibles that you want to concatenate behind the append.
for {set x 0} {$x<24} {incr x} {
set data_in {}
set dataout_h {}
set DFFLO {}
append data_in {HDMI_RX_DAT[} $x {]}
append dataout_h {ddio_rx_24b:\ddio_rx_gen:ddio_rx_24b_inst|altddio_in:ALTDDIO_IN_component|ddio_in_87i:auto_generated|dataout_h[} $x {]}
append DFFLO {ddio_rx_24b:\ddio_rx_gen:ddio_rx_24b_inst|altddio_in:ALTDDIO_IN_component|ddio_in_87i:auto_generated|ddio_ina[} $x {]~DFFLO}
eval {set_multicycle_path -from $data_in -to $dataout_h -setup } $l2h_setup_ref
eval {set_multicycle_path -from $data_in -to $DFFLO -setup } $l2l_setup_ref
eval {set_multicycle_path -from $data_in -to $dataout_h -hold } $l2h_hold_ref
eval {set_multicycle_path -from $data_in -to $DFFLO -hold } $l2l_hold_ref
sstrell
This is an 11 year old post.  Perhaps you wanted to create a new one?
BKevi
@sstrell
This topic was right on the top of my google search result, and it indeed solved my problems.
Although it is an old one, useful to me at least, I think giving feedback is alright.
