16232 Discussions
generate ekp file for arria 10 GX device
NZami
I compile my design with quartus 19.1 for arria 10  GX device and get a sof file.
then I want to generate encryption JIC file. I follow altera instruction but when I add the sof file and press the properties I have only  SOF Files Properties nd not  SOF Files Properties: Bitstream Encryption dialog box (can only choose the compression option).
could anyone help me understand what I'm doing wrong.
NurAiman_M_Intel
Thank you for contacting Intel community.
Have you follow the instruction in AN556: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an556.pdf in generating .ekp File and Encrypting Configuration File (Page 13)?
Let me know your feedback.
Aiman
NZami
Hi, yes I tried to do the steps according to this document but when I reached step j (I think) press the properties of the sof file I add only compression option and not the compression and encryption option and then I stuck. I tried to understand why I don't have the encryption option. Thanks Niv.
NZami
still wait for answer. I be glad for some help here.
NurAiman_M_Intel
Apologize for the delay in response.
Per your response, you are following the correct steps. I have tested, and i got SOF Files Properties: Bitstream Encryption . Can you attach the screenshot of the SOF Files Properties? And what is Quartus 19.1 that you use( Lite, Standard, PRO)?
Aiman
NZami
Hi Aiman
I used quartus 19.1 standard edition
I attach picture of what I got from the sof properties
could it be that I miss somesnip_20200709134248.pngthing in the quartus installation?
Niv.
NurAiman_M_Intel
  1. No. You cannot generate ekp file while using temporary license. Are you using temporary license? Hence I assume that's the reason why you encountered this issue.
  2. Yes, it is possible to run ekp generation on virtual machine. We have tried that before.
  3. We have open your .sof file, however we failed to install your design template into our quartus. (We have tried using quartus and no machine with different computer)
Aiman
nicoh
hi,
I have the same problem.
I'm trying to generate an encrypted .JIC file.
I was able to generate the .epk file (I have a Quartus license)
BTW, I'm using Arria2
