Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
get_service_paths jtag_debug returns null
I am using a DE0-Nano FPGA and I got the follow error every time that in system-console I write the following tcl script command:
set jtag_path [lindex [get_service_paths jtag_debug] 0];
jtag_path does not getting any value and fails in successive steps (ie. opening the service etc..)
I did try the same command with different numbers ie.
set jtag_master [lindex [get_service_paths master] 1];
set jtag_master [lindex [get_service_paths master] 2]; etc... without luck
Appreciate your inputs,
barn[/B][/B]
