I am using quartus prime lite v 21.1 and trying to compile / synthesize and get error
10481 VHDL use Clause error: design library "ieee" does not contain primary unit "float_pkg"
If i look at the directory structure, these files do exist at :
C:\intelFPGA_lite\21.1\quartus\libraries\vhdl\ieee\2008
I tried to set this up in quartus doing tools->options->general->librairies
but this did not help anything, where do i go or how do i set up quartus to point to or use the vhdl 2008 libraries?
VHDL2008 support is limited in the Lite edition. That might be what you are running into.
Reference from KDB:
https://www.intel.com/content/www/us/en/support/programmable/articles/000079430.html
Unfortunately, IEEE fixed_pkg and float_pkg libraries are not supported in the Quartus® Prime Standard edition and Lite edition.
I believe that your question has been addressed. With that, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.
You can add the VHDL-2008 Support Library to your project (files fixed_pkg_c.vhdl and fixed_float_types_c.vhdl) and add this declaration:
library ieee_proposed;
use ieee_proposed.fixed_pkg.all;
The library is available at https://github.com/FPHDL/fphdl
Cheers
![](/skins/images/D0BE44A6F0E2FFF243578BBA9279DBB9/responsive_peak/images/icon_anonymous_message.png)
