Hope all is well, i am just wondering if any one has ever converted simulink model to VHDL codes, or has ever been able to write a matlab function using VHDL rather than c or c++
Tools like DSPBuilder(Altera) or sysgen(Xilinx) hdl coder(Mathworks) do the conversion and not anybody can do that.
Writing hdl for matlab function is not supported by matlab.- Mark as New
using HDL coder you can write M code in a similar style to HDL - but then why not just write the HDL?
Converting simulink models to HDL is non trivial because only a subset of the simulink blocks are supported for code generation, and you will have compilation and timing problems if you do not create the simulink models in the correct way.- Mark as New
Thanks Guys for the reply,
